ve hears how i painted my badge fellas
rusty411
Donating member
mebourne
VE series II Sv6 3.6L ute
SO this is HOW I PAINTED MY BADGE!!
stuffs u needs :p
Primer
paint of choice (plastic)
clear coat if u want more durable
ok stage 1
taking off the grill is fairly easy two screws in the top take them out then pull the centre
off the plugs and then the bracket will follow and lever the grill out. that easy.
then unclip the badge and then reverse the steps to put the grill back in :).
stage 2
give the badge a wash and dry it off, then sand it back with 1200 grit sandpaper enough to rough it up and get the shine out of it so the primer adheres better.
once sanded give it a few coats of primer now dont rush the priming paint and clear coat patience is key. few coats letting it touch dry in between coats this is what it looks like after:
stage3:
once primed let it fully dry for a few hours and then light sand back any major bumps in it very lightly tho once nice and smooth give it a few coats of black plastic paint this is after 2 coats:
this is after all of them
remember not to rush let them dry a little inbetween
step4:
once paint is dry about an hour will do give it a few coats of clear give it 24houts to harden and bang her on the grill and admire your work :)
yZoH
//There Ain't No Rest For The Wicked...
S/E Subs, Melb
www.lolwut.com
(0.o')
It'll chip,
I would of used oven cleaner for about 10minutes, then wear gloves an wash under warm water, it'll take the chrome off the plastic, then you will be left with a raw off white plastic,
Step 2 is some black RIT dye, & some near boiling water for 30minutes, Then remove it.
You have a dyed black badge that will never chip or scratch.
WINNER
--- Same method for R/C car & truck wheels :)
P.S- Using Primer that is not Plastic Primer, Defeats the purpose of using Plastic Paint.. Just thought I would point that out.
Ron Burgundy
NSW
VF II SS
It'll chip,
WINNER
any pics of how this would look
yZoH
S/E Subs, Melb
www.lolwut.com
(0.o')
Like this
If i had a big chrome badge i'd do it to show. It's just I know too many people that have painted over the chrome lion an have had chips within a month on it.
