markovr
- Nov 23, 2003
- 3,072
- 252
- 83
- Age
- 62
- Location
- northside brisbane
- Website
- youtu.be
- 07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
Ever wanted to put your power windows down or up if it started raining and didn't have the keys so you couldn't do it or had to go and find them.
I put a momentary action switch in that puts 12v on the pink 12v ign on wire ( via a diode so you don't back feed every other accessory) to the power window contol box under the dash so when you press it restarts the timer on the power of the windows so you can move the windows without the key and then times out after the set time as normal.
I used the power/economy switch from the console of a vr/s and it looks factory and works a treat.
Basically you cut the pink wire near the module and insert diode in circuit and tee off it on module end of diode through a switch to another tee joint on orange/green wire.
