Siggers86
Hi Guys,
After 3 days of trying to replace the blower fan motor, I finally figured it out. So here is a step by step to remove the motor (not the whole unit).
1. remove grey surround from around the stereo and then the light grey surround.
2. remove the glove box (hint there is a black dowl on the right side that slides out)
3. remove the top lining remove the screws from just under the dash lining at the bottom corners and the grey cover on the side where the joint for the air vent is.
4. remove the air tube that goes along the top of the dash to the rear of the car, by removing the screws on the side near the door, and there is one screw where it joins to the main air system, and I think there is one in the middle somwhere.
5. undo the two screw bolts on up under the dash and the other under the blower itself.
6. remove the cream hatch, there is a dowl holding it in as well wich is connected to one of the phumatic pusher thing, there are a bunch of screws they might look a little rusty, the three on the botom and there are three at the top in the hatch thing i think, also there are 2 screws on either side where the black plastic stops on the side hard to explain I should of taken photos, sorry.
7. remove the metal cover, covering the blower fins, should slide out, might need some persuasion, if still no good, check everywhere for that one that got away.
8. remove the fins from the motor, should be straight forward to remove that.
9. you should be able to see the three screws that come in from the back that hold the motor in place. you wont be able remove all three but the good news is that its held in by gromets.
10. remove the bottom bolt, i belive its a 10mm socket, then remove the other, this one is a little harder to remove but it is doable.
11. this should be it, slide it out the back and thats it, put it back in oppisite direction.
If you have any other questions just ask
