Go to www.k-mac.com.au You can down load an instruction sheet for your model The kit costs about 300.00 buck takes about 1hour to fit . This kit comes with four bushes and an extractor tool for removing your old bushes . also you must get a four wheel alignment
Hope this helps
for the trouble you go through, get it done at a workshop, i got it done and its a relief not to have to do it yourself, and its definitely rewarding, better grip on the road and your rubber will last longer
That sounds about right Pete , i got a quote from Pedders the other week of $395.00 .Thats Drive in drive out including a wheel alignment .
If you are going to go it yourself make sure you get a rear wheel alignment A.S.A.P as you will wear your tyres out in no time if the settings are wrong
confirmed with a mate of mine, $385 for a kit to be fitted (including wheel alignment) however that is only for a HALF camber kit...for the full camber castor kit to be fitted (which is highly recommended) it will be around an extra $100-$150...when i got mine done they said that a half kit would be sufficient, go the full kit, for the extra cash, i was a little tight at the time and when a "professional" tells you its sufficient you generally go with the flow...
