bongoozy
Someone please help me!!
I have changed the power steering rack, pump and solenoid switch to fix the issue where the power steering was failing intermittently at low speeds and restarting the engine should fix the issue.
The job was done by a professional.
Done a BCM reset from the fuse box and wheel alignment after replacing the rack.
But the issue still persists. Power steering fails/becomes very heavy at low speeds power like parking and turning corners and when at full lock while parking or slow turning. If I switch off and restart the engine then power steering comes back to normal until it fails for the next time.
To troubleshoot the issue following tasks were performed:
Check system for error codes - All OK no errors
Checked belt tensioner and belt tightness - All OK
Checked suspension system - All OK
When I reset the BCM the indicators doesn't blink after the reset. Is that an issue?
I am planning to flush the system followed by a system bleeding and install a magnefine inline filter to catch any contamination that was not clean during the rack replacement. Is that the right direction?
Can anyone please give me some more ideas to fix the problem from their experience and knowledge.
THANKS TO ALL MEMBERS FOR THE GREAT JOB..
