i have a vt with superlow kings, some say they are illegal sum say not. i need to know for sure do you know the guide lines is it 100mm ground clearance
Hi mate, should'nt have any problems fitting these. As long as there captive - won't fall out. Kings make a softer ride spring better than the Pedders super low. Hope it helps :w00t:
Sorry to bump the thread up but better then starting a new thread
So Supler Lows (front and rear) will clear 100mm? I have 19's so not sure if that will make it higher of the ground (therefor making it easier to clear the 100mm)?
