brendanssound
- Oct 18, 2015
- 14
- 0
- 0
- Age
- 36
- Location
- Brisbane, QLD
- VX Commodore
Promised myself i wouldn't do this but I am coming to wits end with this car. Don't know a great
deal about the workings of a Commodore motor (Iv always had fords.. ha.. i can feel the hate brewing
already) anyway..
Got a 2002.. i think..pretty sure. VX Commodore V6 and let it be heard here, now and never again..
The car was pretty great. Very reliable, goes good, and sadly i even gave the occasional falcon a
good look at the rear of it as i drove on by (In a safe and controlled environment of course.. )
Had been cruising back from driving my partner to work one day, taking it easy.. no work for me that
day so no rush. Came to a set of lights.. Light turned green.. went to accelerate.. Nothing happened.
Car suddenly jumped back to life (and by that i mean it never stalled or anything.. it just started
responding to my acceleration.) All the way to the next set of lights. At the lights i got a feeling of
near stall then good again. Light turned green.. went to go... did it again. This time it never came back.. Then it stalled.
I got pushed off to the side of the road. Where i was able to start the car again but it idled like a
bucket of crap. Although at that point it did at least idle. If i stepped on the accelerator whatsoever it just
instantly stalled.
Got it towed home, called a mechanic friend who said Crank angle sensor.. So i removed the harmonic balancer,
installed a new crank angle sensor, and have pretty much been fighting ever since (the past few weeks) to
get the harmonic balancer back on where it belongs. (Yes i know.. key way has to line up etc). Had it reinstalled
a few times but it still wouldn't start so i re-did it encase it was slightly out.
i have also checked fuel pump is working (dropped the tank.. can confirm the pump fires up), checked spark...There is
spark, Checked codes.. there is no codes. Unless a scanner tool can pick up other codes?
Yesterday i got it to the point where i am positive its on (yes i checked the key is still in place) and the engine
was at TDC. I even switched out the battery with a small truck battery that i know is good. You can tell it wants
to fire.. At one point i think it did for a split second. But no joy..
May or may not be related to my issue but i also have had the issue This guy has But mine was more like This
Although i had always put that down to previous owner living near the coastline - And had replaced water pump and radiator just
in case. It also had regular oil changes with nothing irregular standing out there. Always used 50/50 water & coolant mix. 2 of the
pulleys had slightly noisy bearings, the right rear brake light blew once or twice, and the car used a good $70 in fuel up over 3-4 days
(Up and down the M1 most of its life) but nothing stood out to me as a problem. We're the 2nd owners of the car.
Partner has got a new car and i will probably return to my fairlane soon.. But i kind of wanna see if i can get this to go again before
rego runs out.. maybe ill keep it on the road a bit while the fairlane gets sorted.
Any ideas?
already) anyway..
instantly stalled.
Any ideas?
