S
syth
Guest
Hi what is the required tyre pressure for Holdern Commodore VT Executive.
Is it different for front and rear tyres....
Thanks.....
Thanks.....
Higher pressure will give less traction.batemada said:i keep mine at 40 psi the ride is a little bumpy but this pressure gives me the best tire wear and fuel economy and grip especially in the wet.
After putting it up i noticed the reduction in drag caused by the tires when compared to when i ran them at 35psi.
I have got 4x Goodyear Decaro GA's on my car and when i got my alignment done i found that i am one of the lucky ones with a series 1 VT that does NOT suffer from the camber problems common with VT's.
