led dash
nsw
falcon
yes once again a led dash conversion
everyones gone with blue so did i till i found was bad on eyes so i went white and blue
the white comes out so nice and clean ya eyes are fine at ngiht on long trips
the blue is low in the background
any q's just ask
Spyper
39
Sunshine, Vic
VX II Acclaim
Wow, that's a very good job. Looks really good mate. How DID you get the backing back like that?
Also, what are the wires in this picture:
http://forums.justcommodores.com.au/attachment.php?attachmentid=18857&d=1148823141
It looks like the light is being separated some how? Can you explain some of that please? I'm thinking of re-doing mine.. it's looking way to rice and the light is very uneven. Also, way too much blue. Dash, A/C controls, and Head Unit.
deserthead
Cairns QLD
VS III l67 Column Shift Ute
Looks great there mate!!
Nice to c some1 mixing it up a bit.
R those indicators in the dash, being blue, legal?
Just curious.
myberlina
BAD COP! NO DOUGHNUT!!!
Melbourne, VICTORIA
2006 VE Calais
I too would like to know how you got the green crap off.
I already have my LEDs in the back as white for the time being but haven't removed any green **** yet.
Looks alright for now but it doesnt fit my long term plan.... muahahaha.
White seems so much better for me.
nsw
falcon
hi guys
ummm i used wet and dry and rubbed like hell
it slowly comes off
i did this to the heater controls to but dont do it it causes green and black to come off and i had to buy new one 5 bux from holdens
the cluster has a seperate chambers for all lights and the way its designed i aimed 1 led into some plastic thingy and it spreds it out
hard to explain but when ya pull it apart youll see what i mean
the spedo/tacho is white leds while indicators are blue leds
i cant see any lawys saying they have to be any color so cross fingers its legal heeeh
Spyper
39
Sunshine, Vic
VX II Acclaim
Yeah I've done the conversion and 'aimed' it at the plastic part.. but it looks like you have separate wires inside there..
nsw
falcon
the wires are only the wires suplying power/earth to leds
heres a tip dont aim leds at the bit ya want to see aim it up a little bit
ive seen 90% dash mods look crap cause ya can see 3-4 spots where leds shine through really badly
N
nickos
Guest
I have a blown globe in my climate control of my VT berlina. I started to remove my dash but found that the part of the dash near the stereo and climate was on really tight. will it clip off or do I have to do other things to remove it? and is the globe soldered on or can I just remove it and plug a new one in?
nsw
falcon
you have to remove the suround from radio/dash/cluster all as 1 peice
then there are 4 screws holding in climate control
the globes are a speshal screw in type from holdens
but cause they 7-10 bux each i took all mine out and use leds only now
