i have a vt berlina 98 model.when the engine is turned off the fan or something keeeps runing,been checking threads is it fan amp under wipers or something worse.
if its the engine fan under the bonnet the low fan relay will be faulty, its a common fault, make sure you get the correct one to replace it, the genuine part is an updated unit it has a white cover.
