Troy
- Dec 15, 2003
- 156
- 0
- 0
- Location
- Gladstone QLD
- VX V6 Auto 128rwkw, VZ V6 Lumina wagon stock
It can be done with a Tech-2, had it done to mine at holden and takes all of 5minutes max.
I have 3.46 diff gears, up from 3.08.
All they have to do is go into the gearbox settings, look at the PPM (pulses per minute), lets say it's 4000, you divide 4000 by the origional diff ratio 3.08, then times that number by the new diff ratio of, in my case, 3.46 and voila, you have your new PPM (in this example 4480) to enter into the gearbox settings so your speedo is correct.
With auto's i think 3.73 are fine to get right but 3.9's will be a little out, manuals i think can go a bit higher to 4.11 and just get away with it but my memory is fuzzy on that one.
This was in another thread, just thought i'd put it up with a different title as i think more people will read/benifit from it titled as such..
Hope this helps. :thumbsup:
