commnz said:
hi, i've got ss inductions cai,mainly open road driving so not to worried about heat soak, redline filter, genie headers which are only made in bigger primarys [ 1.625]inch for s/c engine but i still got them anyway because i want to s/c one day,they are stainless steel and i hpc coated them,plus genie 2.5" system s/s and cat is in the bin. all is mandrel bent. very pleased with results.
If this is the LS1 SS Inductions cai you are referring
to it is strangling your car. Try running around the
block breathing through a straw
Seriously, pull it off the car and take a look at how
small the air path is where it goes into the twin horn
pipe. What is the point of the huge mouth when it
reduces to a 10cm hole before the airbox?
If yours is the old 5ltr then It is probably ok, just
overpriced and poor quality. I just recieved my
Uniflow sealed pod yesterday and the quality
between this and the SS stuff is worlds apart.
daz08, Powertorque in Brendale sell OTRCAI.
Edit: After rereading this thread I have realised
you guys may be talking about V6's, if you are
disregard all the above. The otrcai is only for
LS1 V8.
