homeball
Has anybody had an issue with water getting into the side rail under the passenger door, after driving in heavy rain? I have ripped the carpet out, seat. and all of the lining on the passenger side. The water does not drain at all from this cavity, and I have no idea if there is a drain for it. Eventually, the water fills up this cavity, and spills over to the floor well, while taking corners, braking and accelerating. Water does get into the aireal cavity, but that water drains out of a hole just under the front left wheel arch. Is that supposed to be the case?
