diysv6
- Dec 17, 2005
- 547
- 28
- 28
- Location
- SEQ
- VF S1 SV6 STORM A6: VZ S1 SV6 A5
25 June 2014 UPDATE: The fault was the ECU failing to switch on #4 Fuel Injector - Replaced ECU.
In recent weeks my 2004 SV6 5 speed auto, has exhibited a stumbling idle on hot or cold startup, or when hot after driving for some time. I get no messages on the LCD Dash display, so I am in the dark at present.
The idle is rough/loping but the car does not seem to want to stall. It does not feel like a spark plug miss in the idle. There is a slight fluff at the exhaust at idle but not the dead cylinder noise from a dud spark plug at the exhaust. If I speed up the motor the car runs OK. It seems to be about the idle RPM that the problem is evident. Perhaps it is there under driving conditions, but its effect is unnoticeable.
The only maintenance I have recently done is to replace the fuel filter. ( I pulled the fuel relay and its fuse and dropped pressure by engine cranking etc.) The car does accelerate smoothly and better since I replaced the gunked filter.
As part of the fault finding regime, I have now cleaned the MAF/IAT and the throttle body with MAF cleaner. The TB was fairly clean and no sticking etc.. No oil in the inlet tract, and the PCV was working well at idle. The rough idle has occurred since the MAF was cleaned.
Out of about 50/60 starts the idle has been irregular on five occasions. I normally have the a/c on at all times. (SE Qld). On one start, the exhaust was smelling of raw fuel but the irregular idle was not present. It recently occurred when hot, I turned off the air-conditioning and the problem persisted. I removed the engine cover and could not hear the EVAP, the fuel tank's Evaporative Canister Purge solenoid clicking. I bumped the valve a couple of times, it then seemed to start clicking and when I listened to the exhaust the idle was more stable. There are no vacuum leaks that I can find at present, unless the EVAP is not closing off properly. I replaced the EVAP solenoid hose to the inlet manifold about 15 months back. It is in good condition, no perishing/cracking at the elbow etc.
The other thought I have is that the oxygen sensor "disable" circuitry is starting to go on the blink. My understanding is that for some time after start-up, the oxygen sensors are disabled until the engine oxygen sensors gets up to certain status, and then the oxygen sensors are cut in to manage the fuel metering etc.
Would this coincide with the engine sensors settling down and about when the EVAP would start to click?
Can anyone indicate when the EVAP solenoid should cut in after an engine start? Does the a/c being on have any bearing on the EVAP solenoid's operation?
Do oxygen sensors once failed stay failed or can they drift in and out of correct operation?
My fuel economy is about average at this time. Have not done enough Kms to get another tank full.
I would appreciate your advice.
