Capt Baldman
- Oct 4, 2005
- 23
- 0
- 1
- Age
- 64
- Location
- Melb
- VF SSV Wagon
I have just up-graded from a VN to a VZ Wagon....LOVE IT....however, i'd like to put VE Wheels on it...either SS or Calais wheels.
Now i am aware you have to rebore the centre hub of the VE wheel to fit the VZ, but then i recently came across the following...
Anyone care to comment or know any different...!!
Ta
Holden has told its dealers that the new VE model's wheels won't fit old Commodores.
Holden VE Commodore: production line at the Elizabeth factory in Adelaide.
When Holden introduced the all-new VE Commodore in August it changed some crucial dimensions of the wheel-locating system. This was done to avoid confusion on the production line (as the Holden factory will be building both new and old models for some time yet) and to cope with the new Commodore's extra weight, width and grip levels.
Holden sent the following statement to Drive on Wednesday: "Fitting VE wheels onto a VZ [or earlier model Commodore] is not recommended or condoned by GM Holden as it raises some safety concerns as there are two major differences in the wheels."
Holden said the VE Commodore has 14mm wheel studs and earlier Commodores have 12mm wheel studs.
"If a VE wheel were fitted onto a VZ [or earlier model Commodore] there is a concern that there would not be enough bearing area under the retention nut on the aluminium wheel, which, worse case scenario, means the wheel could potentially fall off."
Ta
