Results 1 to 16 of 16
Thread: Installing an Amp ... how?
    04' VY II Acclaim
    Apr 2006
    Default Installing an Amp ... how?
    Speakers connect to amp ... amp connects to ........ ?
    "Forget Fast and Furious, I Drive Slow and Luxurious"
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by nEb. View Post
    headunit and power... most buy wiring kits which range in types and price. they include all the RCA leads and power cables to hook it up. then just run them all to where you mount it, usually in the boot.
    Power is measured in DECIBEL
    VY SS
    Aug 2004
    SE Victoria
    signal fro mh/u to amp. gets amplified then goes tyo speakers.
    positive power from batt to amp.
    negative power is from the body of the car.
    google it. you will get better general ansers there.
    sganro is offline i speak before i think
    yet another VS
    Aug 2005
    NQ
    Remember to disconnect your battery if you are gonna play around with wiring
    There are no stupid questions, just stupid people
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    basically as everyone has just said...........run your cables off your battery.........i have 2 amps in my boot...........i have a stinger power distributer i run one power into it, then run 2 power off that into each amp, then a ground into each amp and a trigger into each amp...........all 6 speakers run into my 720 watter amp, and i run my sub off my monoblock.............oh yeah and u gotta run RCA's from your head unit to your amp / amps..........
    vs calais eco
    Sep 2006
    Disney land!
    try this let me know how you go and if anyone can point out anything i left out or got wrong let me know
    VY SS
    Aug 2004
    SE Victoria
    dont take this the wrong way but hooking it all up is the easy part.
    nEB will you give anymore input to this thread or have your questions been answered?
    vy commodore
    Mar 2005
    also you have forgot to mention to him that you need to earth the amp it self usually.
    (Screw it to steel) or do some dogdy wireing.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by vyaw2003 View Post
    well i think that usually goes without saying. the wiring kits come with an earth cable but saying screw it to steel doesnt really help, or the dodgy part either. i know parts of my dash that are metallic and arent connected to the chassis/body. You need to find a clean/unpainted surface on the body for the earth. usually a good spot is the rear seat/seatbelt bolts will suffice.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by cxcxcxvcvcvc View Post
    good map but if you wire up the like you would with a battery, you hook the positive up first and connect the negative last
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VY SS
    Aug 2004
    SE Victoria
    no an amp's chassis should ALWAYS be isolated from any electrical connection because of noise.
    so only the neg and pos should be connected.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by vn6pwr View Post
    true i put the earth for both amps behind the back left seat side (the steel that the seat in a VN / VP sedan that the back seat back piece slots onto) but i sanded all the paint off it first............
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    once connected did you spray it with clear coat so it doesnt rust?
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    nope...........didnt get that technical..........primed the area but thats it
  15. #15
    vs acclaim
    Apr 2005
    Could someone help pls. Thinking of putting an amp to run speakers and sub in my VZ sedan. Just wondering what is the best way to attatch the remote turn-on wire. I have a factory HU, should I use acc. wire or 12v output wire. (where does the 12v output wire go to?)
  16. #16
    VY SS
    Aug 2004
    SE Victoria
    does the vz sedan have an electric aerial? if so use that to trigger a relay for the remote wire.
  1. Replies: 21
    Last Post: 15-03-2006, 07:41 PM
  2. installing mi hu
    By jamiekratin in forum Car Audio
    Last Post: 06-01-2006, 04:28 AM
  3. Amp installing
    By BITE ME! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2005, 06:47 PM
  4. Installing a Pod, and where can it be done???
    By MY_95_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2005, 02:00 PM
  5. installing a CAI
    By fu2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2004, 08:26 PM
