had a vt come into where i work one day with the exact same problem, put it in reverse and indicator fuse would blow because they share that fuse. what happened was the wiring harness going to the rear lights had been rubbing on the car body behind the boot carpet so it was shorting out. so maybe look behind the carpet in the boot on the right hand side and just have a good look at the wiring.
