fuse blowing
tex66
vy ute 5.7
my vy ss keeps blowing the indicator fuse when i put it in reverse.... anybody know why????
cheers
caaf
Melb, Vic
www.aurfscan.com.au
VYII Equipe S/wagon V6
It's going to be a matter of working (metering) from the reverse switch on the gearbox to the rear lamps to see if there's any sad bits of wiring.. take the globes and assembly out disconnect the plug from the switch test to the body of the car. It should be open
Supplied is a wiring diagram that should help you.
strgas
GRA = REAL HP
have you a towbar fitted check the wiring connections and condition of the globe holders and bulbs , any recent electrical work to the car ??? alarm fitted or similar .
axemurderer101
Albany
forums.justcommodores.com.au
VY SS
had a vt come into where i work one day with the exact same problem, put it in reverse and indicator fuse would blow because they share that fuse. what happened was the wiring harness going to the rear lights had been rubbing on the car body behind the boot carpet so it was shorting out. so maybe look behind the carpet in the boot on the right hand side and just have a good look at the wiring.
tex66
vy ute 5.7
thanks for the good info...will have a tickle as soon as i can.
mick
