ok need a lil help here,
ive installed my projectors (wh ii internationals)
done the wiring mod, strip the wh and b-wh wiring on the stalk.
hooked the two up with a piece of wire, soldered and taped up.
now when i use the low beams the high beams are on too.
when the high beams are flicked on in car, in the headlights only low beam is on...
where did i **** this up?
or being a 2000 wh caprice do i even need to do this wiring mod?
ok played around a little bit more.....
everything is backwards
i turn low beam on and it turns on my high beams.
i turn high beams on and it turns on my high and low beams...
gah,,,?
anyone please?
just 2 confirm u have genuine WH international headlights goin in yes?
That white wire just needs 2 cut and joined or tapped into the white/black wire and thats it.
yep genuine lights holden spare parts.
done the wire mod yesterday, but disconnected it because lights werent behaving properly
but now everything is backwards
did u cut the white wire so nothing is connecting in pin 2? thats all ya should need 2 do.
no i just stripped both wires and connected them...
theyre not connected anymore
thank you heaps wrx884!
working great now!
