Results 1 to 21 of 21
Thread: Footwell LED's
    VY SV8 M6
    Nov 2011
    Default Footwell LED's
    Hey guys,
    I'm looking to wire up some LED's to the foot well and under the seats in my SV8. I was considering just tapping into the interior light so when you unlock / open doors they turn on with the interior light then considered wiring them to a switch instead. I figured since I wouldn't be driving around with the LED's on it is a wiser option to have it hooked up to only come on when I unlock car / open doors e.t.c. but then figured if I had a switch I can turn them on and off at will.
    Has anyone wired up foot well LED's or neons, and which options did you choose / why?
    VY S
    Jul 2011
    Belmont NSW
    I have mine wired up to the interior light switch, looks good.
    Cost me about $100 all up to get them wired in by my auto electrician inc cost of the leds.
    Cheers and good luck with the install
    Sent from my X10i using Tapatalk
    Quote Originally Posted by showbags View Post
    Seriously dude, that threads over 4 years old. Did they give you a shovel when you joined up.
    VY SV8 M6
    Nov 2011
    Quote Originally Posted by HERONVY View Post
    I was thinking of doing that, but if I can just tap into the wiring in the A Pillar and run cabling under scuff pads it would be a 15 minute job (no soldering, just clip adapters from JayCar), and will only cost ~$50 for the LED's and clips. :-)
    When I get around to it will let you know how it goes.
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    It's been done to death on here. There is heaps of good info. Try a Google custom search of the forums.
    Cheers.
    VY SV8 M6
    Nov 2011
    Quote Originally Posted by morphix View Post
    Scotch Locks?
    Not sure if that's what they're called, JayCar call them Contact Connecters. Can check them out here.
    Quote Originally Posted by VYMAD View Post
    Cheers.
    Yeah, I've looked at all the info and am going to wire it to the courtesy light. My question was more so why people choose courtesy light or switch.
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    I'm considering doing this myself also, but was thinking amount slightly modding the sunglasses holder and adding another separate switch so i can choose to either run the Footwell LEDs via the courtesy lights or turn it on separately, the other switch will act as a bypass more so than anything, if its on, the LEDs are on all the time, if its off, they are controlled along with the courtesy lights/switch.
    My only issue is trying to find a switch that do what i want, eg. cut off the power coming from the courtesy lights switch when this switch is on the 'on' position as i don't want the chance of both switches providing power to the LEDs at the same time and frying them or something worse, etc.
    VZ MY06 SS
    Aug 2008
    VY SV8 M6
    Nov 2011
    I'm considering doing this myself also, but was thinking amount slightly modding the sunglasses holder and adding another separate switch so i can choose to either run the Footwell LEDs via the courtesy lights or turn it on separately.
    I was thinking of doing this too, but was unsure on how to go about it / where to mount switch in VY.
    Quote Originally Posted by derrro View Post
    Hook it up to the ignition barrel lighting to save pulling trim off
    I didn't even think about this, thanks for that idea! (I guess I will still need to pull trim off to get wiring over to passenger side), or is there enough gap up near firewall? I haven't had a good look as of yet.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    My red front ones come on with the headlights but I have a switch on them too. Also have some in the back, on with ignition, seperate switch. I put seperate white LEDs in the front footwells that come on with doors.
    Etc, etc small ones which give a dim glow in the console, small white LED in sunny holder,blah blah.
    The main thing is being able to switch off the main ones when you need to.
    VY SV8 M6
    Nov 2011
    Yeah. That's why I was thinking of connecting it to courtesy light (since you don't need the floor glowing while driving). Might have a look into how I would wire it up to a switch also.
    Sent from my iPhone using Tapatalk
    My 2003 VY SV8 - 6M - SS Kit - De-Badged - Now with a bit of doof-doof.
    VY S/II S Pack
    Apr 2011
    Why not just run them on the current switch...
    Connect the positive on the lights to a constant +12V wire. Connect the negative to the negative ground in the switch, in the VY holder it is the green wire from memory. Easy down, footwell lights that come on when the interior lights are on.
    VY SV8 M6
    Nov 2011
    Quote Originally Posted by MAG00 View Post
    This is what I was going to do, just wire it up to the lead that runs to the interior light, that way when I unlock doors / open doors they come on.
    VY S/II S Pack
    Apr 2011
    Yep, will work fine. If you want to have them off at some time, just put an additional switch on the negative wire between the interior light and the LEDs.
  15. #15
    VY SV8 M6
    Nov 2011
    You mean on, not off right? Because they will automatically go off when the car turns on (just like the courtesy lights).
  16. #16
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    i was thinking of doing this, i've got 2 green l.e.d. sticks lying around, so where do i find the interior light wire?
  17. #17
    Seanyy's Avatar
    Seanyy is offline "HULK"
    VX II Acclaim
    Jan 2011
    Melbourne, VIC
    Quote Originally Posted by Nic92 View Post
    Depending on how much wiring locations change throughout the commodore generations, but in VN - VX models the interior light wires are in the driver kick panel and driver B pillar (the pillar at the rear of the driver's window). Hope that helps
    Quote Originally Posted by TrikkBen View Post
    Get a a few pieces of pvc pipe and make your own extractors... That what I did, it came up great and I gained like 40kw from it.
    Quote Originally Posted by f1tzy View Post
    lol umm how do u accidentally sell a car
    Check out my VX II here.
    Comments/compliments/logical abuse welcome .
  18. #18
    VT S2 - SS intirior - Ls1 Project!
    May 2011
    Sunny coast
    I set mine on 3 way toggle switch all 4 footwells wired to it, UP - ON, CENTER - OFF, DOWN - WITH BASS, and a 2nd switch for the boot, UP - ON, Center standard boot light turns them on, DOWN, With bass..
    With bass is just for wank factor at night..
  19. #19
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by Seanyy View Post
    \n \n
    Yeh, VY is the same. I pulled the B pillar trim off, located and tested the correct interior light wire, then when I knew the correct colour, I just tapped into it under driver's scuff plate.
  20. #20
    Seanyy's Avatar
    VX II Acclaim
    Jan 2011
    Melbourne, VIC
    \n \n
    Sup with the \n \n ?
  21. #21
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Dunno, it's been coming up on it's own on this stupid Thub I'm using, as my computer's carked.
  1. [VE] How to install LED's in Footwell of VE Commodore
    By SteveHatz in forum Holden Commodore How-To's
    Last Post: 09-12-2011, 10:55 PM
  2. footwell led's help
    By vn_lexcen_s2 in forum Electrical Wiring / Questions
    Last Post: 19-09-2006, 11:44 AM
  3. footwell LED's
    By TI0350 in forum Electrical Wiring / Questions
    Last Post: 07-09-2006, 10:17 AM
  4. LED's and Dimmer
    By Jules86 in forum Electrical Wiring / Questions
    Last Post: 03-05-2006, 10:09 PM
  5. LED's
    By emmtee83 in forum Electrical Wiring / Questions
    Last Post: 03-05-2006, 07:14 PM
