Loveit
- Nov 26, 2012
- 27
- 0
- 0
- Location
- Australia
- Monaro cv8
Hi
As some of you might of recognised i had a problem starting my monaro a few weeks back but i fixed that with a new bcm fuse ( even though the fuse was perfectly fine)
Now i can only start the car by bridging the starter relay pins 87 and 30 the car will start perfectly when i do this
I checked all the wires coming into the start relay and one is suspect which is pin 86 i think this is an ignition source but not sure its a small grey wire .... I dont know where it comes from
A wiring diagram i found says it goes to a fuse .... The fuse box lid confirms this but the fuse is non existant and there was never terminals for a fuse in that location
Does any one have any idea where this wire goes???
Vx monaro
Vx monaro
