nes138
- Feb 6, 2012
- 555
- 2
- 18
- Location
- Gippsland Victoria
- FC HOLDEN with 5LT V8 (VT)
Ok so the complete VT SS series 1 harness is in my 1958 FC Holden, looking at using the FC switch if possible. I joined the white/black wires from the indicator stalk to be a continuous circuit and on the vt headlight switch joined the grey and brown/blue wires to permanently have the dash lights on. I want the parkers to come on with the headlights and then the high beam when the chrome stalk is pulled out to its second stage. I used the dark blue/yellow high beam wire from the indicator stalk to activate the high beam. On the FC light switch power is at the bottom with three positions up the side. Position 1 nil requirement although I have the light blue parker wire connected, Position 2 with white/black standard beams and position 3 with blue/yellow high beam. Its a simple pull rod switch where you pull out a click and beams on and next stage is beams plus high beams.
So far the head light and the high beam selection is perfect.:beer chug:
Problem one: as this is an SS the manual has no ident for wiring, as in has guide for exec then berlina then calais and states the light blue wire (in photo not connected) is parkers for exec but foglamp for berlina and calais. The original car had foglamps but I can't see where another dedicated parklamp wire is sowhen I connect this to the headlight to activate parkers (the parkers activate) but the indicators come on solid and cut the dash lights out as per photo.
Problem two: there is a black/green wire that is not in the manual so I have no idea what it is for BUT, the manual states there should be a grey/red wire and there is no wire here in that colour.
Can anyone suggest a better method of connecting these up (I'd even be happy to leave it on auto the whole time).
