Help new battery no power to ignition?
Apples29
Whyalla south Australia
Vs panther statesman
I have just put a new battery in connected up all right , I'm getting 12 volts at the starter but absolutely nothing at the ignition, what's up please help!!!
Sent from my iPhone using Tapatalk - now Free
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Check your fuses and fusible links.
They may have blown when you hooked it up.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Good to hear. Easy fix.
Just make sure you disconnect the battery first before you replace the fusible link as I think on those models they are held in by screws.
Negative off first...Negative on last.
