Results 1 to 15 of 15
Thread: Replacing plugs on your alloytec( Not dial up friendly)
    05 VZ Calais 3.6
    Aug 2010
    koo wee rup
    Default Replacing plugs on your alloytec( Not dial up friendly)
    Things Youll Need.
    Music
    10mm Socket
    13mm Socket
    16mm Plug Socket
    Multi Grips or Pliers
    Phillips head
    Flat Blade screw driver
    6 Spark Plugs(i got mine from holden but you can get them from Autobarn aswell)
    1 pair of inlet Manifold Gaskets
    First things First, You have to pull of these 2 Vaccum Hoses
    Undo this Bold with your 10mm socket
    Undo the 3 screws holding the Airbox lid on Using a Phillips head
    Remove radiator Cover by using your Flat bladed Screw Driver
    Now Unplug your AFM
    Undo the Clamp on your Induction pipe with a small shifter, Unplug the Throttle body(underneath), And take off the vaccum hose on the left hand side
    Use Pliers to squeeze the clamp on the Master Cylinder vaccum hose and pull it off, Unplug the to plugs just behind the manifold and undo the 6 13mm bolts holding down the manifold
    You are now faced with this
    Start by undoing the 6 10mm bolts Holding down the Coil packs, they should now just pull out and now use your 16mm plug socket with extension to remove the plugs
    Now clean the Runner gasket area with some Metho or petrol and a razor blade( WARNING: TRY NOT TO DIG THE BLADE INTO THE SURFACE AS IT WILL CUT GROOVES INTO EASILY AS ITS ONLY ALLOY) once that is done Place new Gaskets and reverse all the steps and your done
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    good how to mate.
    would come in handy for alot of people who have no idea if they upgraded from ecotec to alloytec.
    2004 VZ Commodore
    Jul 2010
    when replacing the inlet manifold gaskets, do you use sealant before putting the manifold back on??????
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by eirkal View Post
    Wouldnt hurt, Since it is like $5 for a tin of it
    good write up
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by VKCOMMO View Post
    good write up
    There's no need for sealant as the gaskets have locating lugs to stop them moving around and once the bolts are in, they wont move.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    God bless my Ecotec. I remember trying to change the plugs on my brothers Camry, wasn't that a royal PITA.
    Ronald Reagan (1986)
    VZ Berlina
    Aug 2004
    Excellent tutorial,will save a lot of time when the time comes to change the plugs.
    Thanks
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Good How to Mate,
    I Had no clue with these and doing a service. No wonder i have never seen the plugs cause did not know you had to pull the whole air intake off lol
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    You make it look too hard mate, just undo the plennum bolts and shove a couple of blocks of wood in between the plennum and manifold. Doesnt matter if you mess up the old gasket, coz it gets replaced anyway. Dont remove the whole thing.
    VZ SV6
    Nov 2010
    North shore NSW
    Quote Originally Posted by VzVzVz View Post
    He didn't say it was the quickest way, just a way he's done it without hassle. A full R&R makes you learn a lot more than just prying away what's in the way in the hope you'll have space to actually work in.
    And I'm pretty sure he was commenting on the lower intake manifold, not the gasket, the gasket is probably paper based, the lower plenum is alloy!
    Does anyone have the part numbers for the inlet manifold gaskets? Are they the same between the 175, 190 and 190 '05 update?
    Cheers and thanks SLIVZ for the how-to, pictures always make doing shit in the engine bay alot easier
    Greg.
    VZ 3.6 S
    Oct 2009
    HMMMM i followed this tutorial and now the engine is idling very roughly....not sure what to do...?
    VZ 3.6 S
    Oct 2009
    Ok turns out i didnt tighten the spark plugs to the correct tightness (between 16Nm - 20Nm). After getting a decent torque wrench from Autobarn I pulled everything off again and tightened to the correct torque and took it round the block...Feels really smooth now and can definitely notice the extra power the new plugs have given me back...(the old ones were in quite poor condition).
    VZ SV6
    Nov 2010
    North shore NSW
    Glad you worked it out and saw an improvement!
    The instructions on the plugs are pretty straight forward but in case you missed them, the easiest way to make sure you get a proper seal without a torque wrench particularly on older cars is to do the following:
    Do this one plug at a time and don't leave the plug holes in the block open too long.
    1. Pull the spark plug out and clean the thread of it with petrol or similar cleaner. You can use this same plug for the rest of the cycle.
    2. Use a proper plug socket to thread the plug back in and out a few times of each cylinder to clean the threads in the block, as if there is debris or excess oil in the threads, that can give you a false torque 'reading'. Debris will obviously also wreck the threads if coarse enough, as most blocks are made of softer metals.
    2. Once you're happy with the cleaned thread on the block, using only the shaft of the socket extension thread your new ones in with one hand and tighten it as much as you can. Unless you've got rubber for hands and are built like a truck then 'hand tight' is pretty standard between most people.
    3. Then use your socket wrench to further tighten the plugs using the instructions as a guide. Most of them say 3/4 of a full turn, some say 1/2. Depends on the plugs.
    Doing that should ensure you get more or less the correct torque on the plugs and prevent leakages and snapped threads / heads.
    Just some FYI cause I feel generous tonight
    -Greg.
    Quote Originally Posted by azza221 View Post
    2005 SV6
    May 2012
    Australia
    is there a torque setting for the 6 13mm bolts holding down the manifold at all? im assuming the coil packs are just by feel, just wondering about the manifold bolts themselves
  15. #15
    Shooter03's Avatar
    Shooter03 is offline Nek Minnit
    Vz wagon
    Feb 2012
    Narre warren
    Good stuff mate. Thanks for the how too.
    I Used To Have a Open Mind But My Brains Kept Falling Out
    Originally Posted by drewVHSS
    If you wish to buy that, i have some sweat from the ball sack of an elderly yak, if you rub it on the rocker covers of your engine, it'll unleash 1-2 killerwasps of powah!.
  1. How to: Remove VE door trim (not dial-up friendly)
    By TehFastyOne in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-04-2012, 03:10 PM
  2. VZ alloytec (how do i change spark plugs)
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-02-2012, 04:08 PM
  3. Replacing Spark Plugs
    By alien in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-11-2009, 09:14 AM
  4. My 1981 VH SL/E (not dial up friendly)
    By clubsport_replica in forum VB - VC - VH - VK
    Last Post: 02-06-2009, 09:34 PM
  5. Replies: 2
    Last Post: 15-09-2007, 10:30 PM
