Glad you worked it out and saw an improvement!
The instructions on the plugs are pretty straight forward but in case you missed them, the easiest way to make sure you get a proper seal without a torque wrench particularly on older cars is to do the following:
Do this one plug at a time and don't leave the plug holes in the block open too long.
1. Pull the spark plug out and clean the thread of it with petrol or similar cleaner. You can use this same plug for the rest of the cycle.
2. Use a proper plug socket to thread the plug back in and out a few times of each cylinder to clean the threads in the block, as if there is debris or excess oil in the threads, that can give you a false torque 'reading'. Debris will obviously also wreck the threads if coarse enough, as most blocks are made of softer metals.
2. Once you're happy with the cleaned thread on the block,
using only the shaft of the socket extension thread your new ones in with one hand and tighten it as much as you can. Unless you've got rubber for hands and are built like a truck then 'hand tight' is pretty standard between most people.
3. Then use your socket wrench to further tighten the plugs using the instructions as a guide. Most of them say 3/4 of a full turn, some say 1/2. Depends on the plugs.
Doing that should ensure you get more or less the correct torque on the plugs and prevent leakages and snapped threads / heads.
Just some FYI cause I feel generous tonight
-Greg.
Ok turns out i didnt tighten the spark plugs to the correct tightness (between 16Nm - 20Nm). After getting a decent torque wrench from Autobarn I pulled everything off again and tightened to the correct torque and took it round the block...Feels really smooth now and can definitely notice the extra power the new plugs have given me back...(the old ones were in quite poor condition).
