Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By MEESEN
Thread: How to Install Front Power Window Regulators into a VY
    MEESEN's Avatar
    MEESEN is offline V8 6 Speed coming :D
    '03 VY
    Jun 2010
    Cool How to Install Front Power Window Regulators into a VY
    Ok, This isnt covered in the "How to install Power Windows" thread so ill quickly cover it for anyone interested...
    What You'll need:
    • 2 People
    • 10mm spanner or socket
    • Rivet Gun
    • Pop Rivets (to fit holes)
    • 4mm Drill Peice
    • Drill
    • Door looms with Power Window Connecter
    • T15 torx driver
    What You'll need to do:
    1. Remove your door trim & Remove the plastic
    2. Remove Speaker and Side mirror (done buy supporting mirror and removing 3 T15 Screws then disconnecting the wiring)
    3. Remove original wiring and replace with door looms that have a power window connection
    4. Re attach side mirror
    5. Wind the window down 1/4 of the way (so its 3/4 up) and have your assistant hold the glass supporting its weight
    6. Remove the two 10mm bolts on the slide rail
    7. Drill out 4 pop rivets (your assistant now has the whole weight of the glass)
    8. Remember how the regulator is attached to the glass and then maneuver the regulator until you can get it out
    9. Slide in new electric regulator and attach to glass rails
    10. Line up the regulator support bracket with the 4 holes you previously drilled out and rivet into place (Your assistant may need to raise or lower the glass a tad)
    11. Re-fit the slide rail with the two 10mm
    12. Connect Door loom to the new regulator
    13. Check to make sure it moves up and down freely
    14. Replace Plastic & Door Trim
    and your done!
    Commodore VY Executive
    Jul 2010
    Metford
    Cheers for that mate but I had already sorted it out lol also I had spare 10 bolts from the car I removed the regs fro
    So I used them instead of rivets
    I hate rivets
    Cheers anyway
    MEESEN's Avatar
    '03 VY
    Jun 2010
    VT SS 5.7 s2
    Oct 2011
    melbourne, western suburbs
    awesome!!!
    so this is straight foward? for a novice?
    what is the time this roughly takes?
    instead of putting new rivets in, is it possible to use bolts?
    and is there anything thing else i should know? little handy tips or secrets?
    cheers
    MEESEN's Avatar
    '03 VY
    Jun 2010
    Took me about an hour, including time to take photos and that mate,
    And yes you can use nuts and bolts instead,
    VT SS 5.7 s2
    Oct 2011
    Oct 2005
    Thanks for that. The photos and description made it an easy job. I was working one out so I clamped wood either side of the window running down to the door to stop the window falling. Don't tighten the clamps too much, I used two small slide clamps. Easy to get the crank out with the window 1/4 down.
    Cheers Geoff.
  1. vt wagon rear power window regulators are they the same as sedan
    By r600 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-02-2011, 04:28 PM
  2. power window regulators fall off
    By jeepster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2010, 07:24 PM
  3. VH power window regulators
    By whitey66 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-10-2009, 02:39 PM
  4. Aftermarket power window regulators
    By _R_J_K_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2009, 03:37 PM
  5. Power window regulators
    By coolngroovy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2008, 04:56 PM
