Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By capitalgainz
  • 1 Post By HarmlessMuffinMan
Thread: How to change sway bar link rods
    VX Commodore 2002 Executive v6. Ex Patrol Car
    Nov 2010
    Armidale, NSW
    Default How to change sway bar link rods
    Aw yeah! Here we go.
    Ok! First step peeps! Eggs!
    Thats right! Eggs, cook em, eat em, rub em on your body, I don't care! JUST EGGS!
    Step two! Jack yo car up foo'! And best be using those car stands as well, because if you don't use em and you get crushed... SUCK IT! Thats what we call "Natural Selection"
    Also take off your wheels... Only your front ones.. Don't take off your back ones.. Kay?
    YEAH COME ON!
    Old on the left! New on the right. I got NOLUTHANE BITCHEZ! You don't have to do that but you can, I don't care!
    Step THREE! (This is the step after two)
    Sixteen MM spanner, take that bad boy and remove the bolt on top of the original pin!
    Now its time for step four (But please complete step 3 first)
    14mm Spanner! Remove the bolt behind the ball joint! You may need to use another spanner to brace the inside bolt, as when the ball joint is ruined, it will spin!. I used a ratchet son!
    I dont wanna use the step method anymore! So its time to mix this crap up! If your a smart kid, you will realize you don't have a pin in there anymore! Now its time to put the new pin where the old one was!
    Thats how the pushes have to be setup on the top! Now put it in and tighten up the bolts with a 17mm spanner son! I used a ratchet for behind the ball joint, because I'm super bad like that!
    Don't leave it like that boytoy! Take a 12mm spanner and under the top bushes there is a bolt part of the rod, once all bolts are tighened, use that to straighten the ball joint up! YEAH!
    Now your finished! I would recommend doing the other side!~ and putting your wheels back in!
    EGGS!
    Also thats what the bushes looks like before I replaced them. They were being very naughty bushes.
    Fart noises, women can't drive, and gay people are gay. IF YOU HAVE ANY QUESTIONS ASK!
    Problem Just Commodores?
    Hover Hand!
    2003 VY SS series 2
    Sep 2009
    Brisvegas
    Mk2
    Mk2 is offline
    VX Calais S2
    Oct 2010
    I have a clunking noise when I turn full lock at slow speed, and when I chucked different wheels on my car I noticed the screw on top of the pin was a little loose. Could this be the source of my problem? I am going to probably replace near on everything under there when I lower my car anyways but if it's just a matter of tightening it up some more I'll do that for the interim. I just wasn't sure if it was supposed to have a little play for movement or not. This may be a stupid question, I am unsure.
    VY S Series 2
    May 2010
    always wondered whether that rod should have a slight curve in it lol now i know
    out of curiosity where'd you get the bushes and rod from??
    btw you missed out on the possibility of so many rod jokes
    VT V6
    Sep 2009
    Mk2
    Mk2 is offline
    VX Calais S2
    Oct 2010
    Quote Originally Posted by Dr HaxZaw View Post
    Something something rod in your bush something.
    VY S Series 2
    May 2010
    Check the rod is straight before continuing... Insert rod into hole
    the list goes on lol
    Jarrad is offline Sherminator
    Silver Ex Cop VX Wagon
    Oct 2006
    Wollongong
    Another cracker mate, well done!!
    Quote Originally Posted by monkeys437 View Post
    Its faster to drive very slowly than walk very quickly so hang onto your license and drive like a grandma for a year.
    Now you see me... Now you don't
    Nov 2010
    Armidale, NSW
    @ AUSFITTER -- Not 100% sure, but I think the only difference is you have two ball joints, i.e. no bushes... Go find out and tell us! All you have to do is remove your wheel!
    @ MK2 -- Could be one reason, Sounds like what I had before I replaced mine. Does your front feel very loose? like leaning ALOT? Chances are if you have to replace one bush, you have to do them all... Good luck!
    @ Dr HAXSAW -- Got them from Repco. No they are not supposed to have a curve in them. Per rod jokes: Too easy :P I want my humor to open up your brain and #### it like a tripple ####ed hooker, not make you giggle.
    @ Jakeobe -- Not a problem, did you find the how to to be exact? or did I #### something up?
    @ Jarrad -- <3 x 30 . May many virgins find there way into your rape dungeon tonight.
    VY S Series 2
    May 2010
    Yes i did notice it was full of some very sophisticated humour lol
    lol as for the curve i geuss im gonna need some new ones
    Nov 2010
    Armidale, NSW
    Yeah dude, honestly you can replace JUST the bushes... But I garentee you will need to replace the rods due to the ball joint before the bushes go again, so better and cheaper to replace the whole thing. They are probably already on the fritz anyway
    vt equipe, vt exec, 97 wrx LE
    Sep 2008
    adelaide
    i followed the instructions and ended up with cheese toasties, i started with eggs and no sway bar link pins but then BOOM cheese toastie!!
    Nov 2010
    Armidale, NSW
    vyseriesII's Avatar
    vyseriesII is offline The V6 is MACEd
    2004 Vy S Series II
    May 2011
    Is it ok if you cook bacon with the eggs? Or is that just messing too much with the procedure?
  15. #15
    '98 VT HSV XU6
    Sep 2011
    Tarneit, Melbourne
    Nice write up as always on a side note how much did u pick up the pins and bushes for?
  16. #16
    Nov 2010
    Armidale, NSW
    Pins I picked up for $89 dollars from Repco (They are usually $140), bushes I picked up for $24.
    Yeah, I suppose you can cook bacon with it. But if you do that, make sure you do the whole procedure with a hat on.
  17. #17
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    I just completed this today. what a easy job to do thanks to this write up. I got my complete kit off ebay for $64 included postage. It come with pins and bushes.
    One question tho. did you grease the rubbers at all? None was supplied in the kit so i didn't. Its just the old ones seem to have some old white grease looking shit on them thats all.???
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
  18. #18
    VX S series II
    Sep 2010
    Quote Originally Posted by HarmlessMuffinMan View Post
    I got a nolathane kit from repco today and the bars are curved.
  1. Wasp Sway bar Link Rods
    By HarmlessMuffinMan in forum General
    Last Post: 20-08-2011, 05:40 PM
  2. Replaced swaybar link rods car now pulls to 1 side
    By Farqhed in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-10-2010, 08:01 AM
  3. link rods-vn to vs
    By comaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2010, 12:49 PM
  4. Link Pins (Rods)
    By hsvd_g in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2005, 10:52 AM
  5. VN sway bar link kit??
    By stockVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2005, 03:04 PM
