Lumps of cheese
welcome to the machine
- Nov 19, 2005
- 2,770
- 40
- 48
- Age
- 45
- Location
- Warrnambool
- 83 vh sle, 4x4 hilux, 03 monaro, 07 nightrain
Hey all,
I know there is some threads around with some instructions here and there on how to do this but since i was doing this today i thought i'd take some snaps whilst doing it to help people along. Keep in mind this is just a guide and i take no responsibility if you stuff it up cutting corners and end up wearing your airbag!
For starters, disconnect your battery and leave for a period of time before starting, 10-15 should do it.
Also make sure that you have your front wheels straight as well as your steering wheel so you don't go putting it back on crooked.
1. Take a small flat blade screwdriver and insert into the slots on the back of your wheel. There are 2 per side, once in turn the screwdriver whilst gently pulling the airbag towards you, you will feel the airbag come away slighty from the wheel.Continue this until all 4 are done and the airbag should be free of the wheel.
2. Once the clips are released you'll have to unplug the bag. Gently remove the yellow plug in the centre of the bag shown below, then remove the red wire also from the bag assembly. The airbag will now be completely free of the wheel.
3. Place your airbag facing up away from the car just in case, heard a couple of stories of bags going off!:yeah:
Grab a phillips head screwdriver and undo the screw holding the green wire to the wheel.
4. Undo the clip connecting the steering controls shown below.
5. Using a 30mm socket with extension undo the centre nut of the wheel.
6. Thread wire looms through opening at the back of the wheel and gently slide the wheel towards you off the spline, the wheel should now be free.
7. If you are changing your spokes on your wheel grab a phillips head screwdriver and undo the 2 gold screws on the wheel as shown.
8. Flip wheel over and grab the plastic case and just pull towards you, it should come free of the wheel and expose the screws holding the spokes in.
Work in reverse to fit your wheel back up, just remember not to hook your battery up until everything is back together!
