Giggity
- Dec 29, 2010
- 29
- 0
- 1
- Location
- Adelaide
- WK Caprice 5.7
Hi guys n gals!
Three (yes effin three) years ago now, my radiator dumped all of its coolant and I coasted home about 400m, the temperature gauge never went over half, the car didnt overheat, all was ok, I replaced the radiator and the thermostat and was on my merry way, after this incident however Ive noticed that the temperature gauge will rise up to about 5mm over half (114c), sit there for about 20-30 seconds and then drop back down to a third (98-102C), now this will mainly do it on slower traffic and at traffic lights, I also thought I might add, that if its getting hot and I stop the car, leave it for a few minutes (lets say at a servo to fill up) then get back in and drive it, the first initial acceleration will cause the temperature gauge to leap up and drop back down fairly quickly.
Another thing is the longer I drive it, the higher the resting temperature becomes, so instead of it heating up to over half and then back to a third, itll be resting at half and heat up to 3/4.
The parts I have now replaced are
Radiator x 2 (now has a high performance alloy)
Thermostat x3
Waterpump
Overflow bottle cap
Coolant temperature sensor
Thermo fan relays
Aftermarket trans cooler
Has been TK Tested
Isnt losing a drop of coolant
The first picture is its resting temperature, the second is the hot zone
Thermostat x3
Waterpump
Overflow bottle cap
Thermo fan relays
Has been TK Tested
