2003 VY 3.8 constant spike in temperature
jays2
65
Glen Innes
VY
Update :
took the VY for a test drive today. Went great for 145km.
Then suddenly temp gauge shoots up , alarm goes off , "Engine Temp HOT" on dash. But comes back to normal running temperature within 20 seconds.
Turn around heading for home. Temp needle creeps back up again 2 minutes later. Fans come on , alarm going off, Dash gauge reading Hot.
Jumped out and grabbed the digital infrared temp thermometer. Top hose 77°C & bottom hose 40°C while dash gauge is still reading H. Comes back to normal temperature.
Shoots up and goes down again a few more times .
Any ideas?
Immortality
Staff member
Sth Auck, NZ
I'm gonna suggest the temp sender is playing up, but...
Did you check the top radiator hose for pressure?
Did you hear any boiling/bubbling noises?
jays2
65
Glen Innes
VY
No boiling or bubbling noises.
Top radiator hose is firm
jays2
65
Glen Innes
VY
I just put a new temp sender in it , the one under the thermostat. Is that the only one?
Immortality
Staff member
Sth Auck, NZ
krusing
Melbourne, Bayside
Sometime ago I had a fault of loosing coolant,
Not leaking it, not a drop on the garage floor.
But the engine was consuming it,
And I did notice a lot of steam out the exhaust while idling,
I pressure test it, and would not hold preassue, and not leak it, so it had to be going somewhere,
I put it down the LIM gaskets,
I have since replaced those, and it’s been running great,
That said,
I did read you replaced yours, just wondering If you cleaned the inlet surfaces on the manifold and head surfaces, as the surfaces on mine were just gunk from the radiator, I even used a smooth file and ran it side ways to clean/re-surface the inlet manifold.
After all the prep work, as mentioned, it’s running great.
Cooling systems are a bit tricky to fathom out sometimes.
jays2
65
Glen Innes
VY
That said,
Yes. Did exactly that. After scraping and cleaning and rubbing back the heads & the inlet manifold with wet and dry, I wiped it down with wax and grease remover then when it was clean , fitted the MACE LIM gasket & the manifold.
It took forever.
Immortality
Staff member
Sth Auck, NZ
Did you use a thread locker or some type of sealant on the bolts?
Immortality
Staff member
Sth Auck, NZ
It's not fitted with an aftermarket LPG system?
