pedrotski
Big Stato!!
- Jan 14, 2008
- 396
- 2
- 18
- Location
- Mandurah
- Website
- www.whitcroftit.com.au
- 95 & 96 VS 5L Statos
Hey guys. Since fitting a twin 2.5" exhaust system to my car, I have lost a ton of power over pretty much the entire rev range, Esp down low.
I didn't think it would be an issue with a stroker engine. Also considering the stock pipes are twin 2/8th inch, the power loss is insane. Must say im pretty annoyed atm, Even tho it sounds mint.
I also have a flat spot where i have almost no power in the higher rev range, The flat spot covers about 1500rpm before redline.
Any ideas?
I have changed plugs, reset ecu, oil change, gearbox service.
To give you an idea on the power loss, I could put my foot down in first and it would light up through the entire gear with 235's and then chirp/axle tramp into 2nd. Now it cant even light up 1st if i just put my foot down and it wont chirp 2nd because of the wild flat spot.
edit, bad tune?
Any ideas?
edit, bad tune?
