Apply air pressure to the J 35667-A J 35667-A and adjust according to the manufacturers instructions.
Record the cylinder leakage value. Cylinder leakage that exceeds 25 percent is considered above acceptable and may require component service. In above acceptable leakage situations, inspect for the following conditions:
• Air leakage sounds at the throttle body or air inlet hose may indicate a worn or burnt intake valve or a broken valve spring.
• Air leakage sounds at the exhaust extension pipe may indicate a worn or burnt exhaust valve or a broken valve spring.
• Air leakage sounds from the crankcase, oil level indicator tube, or oil fill tube may indicate worn piston rings, a damaged piston, a worn or scored cylinder bore, a damaged cylinder block or a damaged cylinder head.
• Air bubbles in the cooling system may indicate a damaged cylinder head or a damaged cylinder head gasket.
Perform the leakage test on the remaining cylinders and record the values.
