The block is a high compression 308 block cast 24th May 1969, very early production, in fact one of the earliest I've seen. The Holden 308 was first released in the HT Brougham while existing stocks of the Chev 307 were still being used in other model variants, and the Brougham wasn't released until June '69 so this block would've been among the first Holden V8's ever!
It should be a Trimatic bolt pattern, neoprene rear main, with no webbing around the rear main journal casting and the two extra head bolts. If it still has the original bolt-ons it will have no oil filler in the rocker covers but instead the long tube coming out of the timing cover with the vented cap.
The cylinder heads are all over the place:
The 9947423 part number with a cast date of 10th December 1981 is off an early blue motor (excl HDT) that came from either a VC Commodore or a WB Holden, could be either 253 or 308.
The 92027335 part number with a cast date of 5th June 1987 is off a black 304 (LV2 option) V8 from a VL Commodore.
Both heads should have the square EGR ports and the two extra inlet manifold bolts. Also note that if both heads still have the factory valves and seats then only the VL head is suitable for unleaded petrol.
Andrew
