308 vacuum issues
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
our 6L stroker vn 304 made 350rwhp on 28 degrees of timing on pump fuel through a full exhaust using yella terra alloy heads and a smallish street cam not your average 308 LOL
Dsmitz
1980 vc commodore
350 from a carby 308? you were fkn dreaming bro. that'd need to be tuned to within an inch of its life and not running a 4k stally.
That's what I needed to hear mate.
Sent from my iPhone using Tapatalk
ari666
250,000 hits
Dsmitz
1980 vc commodore
Took it to a shop this morning to get the pipes from the extractors to the single 3" exhaust made up, more $$$, and then trying to get it to wa performance to check my afr and get a second dyno reading. But just to avoid confusion the old exhaust was twin 2.5" to single 3", the outlets on my new headers are 3" so I have to match up that so the exhaust will then be twin 3" to single 3" (for now, the funds are running out lol) then down the track prob go twin 3" to single 3.5" or twin 3" all the way with a cross pipe.
Immortality
Staff member
Sth Auck, NZ
Your probably better off going twin 2.5" all the way rather than going into a 3" single with only 1 muffler. Also fit a balance pipe.
Deuce
Super Stock
'94 VR SS V8
if it is 3" outlet on Extractors, use a reducer to bring it down to 2.5", keep twin 2.5" and through 2 parallel mufflers.
then join to a single 3.5" if you want.
should be good for over 400crank Horse's. Any bigger exhaust will be overkill and drop your low end torque out too much
Dsmitz
1980 vc commodore
Is that what most people run with my combo, pretty sure they run twin 3 or twin 3 into single 3, maybe I'm wrong? I mean, wouldn't it choke up a bit running 1 3/4 headers with 3" outlets to twin 2.5" to single 2.5"?
Dsmitz
1980 vc commodore
1 3/8 headers I meant
Immortality
Staff member
Sth Auck, NZ
Don't you mean 1 5/8" primary?
A full twin 2.5 is good for about 500hp and flows more than a single twin 2.5" into single 3". There is a thread around here somewhere with a chart showing pipe diameters and HP potential/flow etc.
