Didn't need a machinist on this particular block, when I stripped it, I could still see the cross hatches from the previous hone, measured the bores and they were all round.
Yes, it was at Gazzanats, Tiger Micre VC with a VK body kit, Andromeda. Made top 50, but let go right at the end of the burnout. Pulled it apart in the pits and discovered #2 with a hole in the block and piece missing out of the piston.
It would depend on how much machining is needed. To do it properly, line boring of the crank and cam journals is a good idea. I haven't paid for machine work in quite a while, so I really don't know.
Assembly is quite easy, just take your time and make sure the rods are around the right way. Biggest chamfer to the crank. A torque wrench is a must if you haven't already got one. The assembly plasti gauge for bearing clearances are a good idea too. (It's like plastacine that you fit between the bearing and the crank, when you torque the bolts up, the gauge squishes out, and you put the flattened out strip on a scale to tell you the clearance you have.)
Use assembly lube on all the bearings and running in lube on the cam if going a new cam (Flat tappet only, roller doesn't need it). I learnt the expensive way that turning an engine over too long will wipe the lube off and destroy lobes. Thanks to a stuffed Hall Effect Sensor on one cam and a lifter that didn't pump up on the second cam, I was on the third cam when it finally ran it properly. It needs to fire up straight away and hold revs at least to 2000rpm for about 20 minutes to get some heat into the cam.
You will need a ring compressor to fit the pistons into the bores. Check end gap clearances before you fit them.
It sounds complicated, but making sure everything is checked before final assembly will get you a good result. Took me 3 nights of about 3 hours a night to assemble my stroker. I also had to clearance the block as it was the original 308. Very easy to do though. I did it with a 5" angle grinder lol. There is a bit of a build on my Facebook page, the link is in my sig.
