6 speed auto reliability? 2011 VE Commodore
Crocodile
Gold coast
2011 VE THUNDER COMMODORE UTE
what would you give the 2011 ve commodore 6 speed auto out of 10 in terms of all round... reliability, response... etc
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
V6 or V8 version?
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
It’s all in the model code. The 5L40E is the weakest of the bunch. The 6L50E is next up on the list then the 4L60E. The winner for strength and durability is the 6L80E fitted to the V8s.
The two digits I’ve bolded tell you the power handling rating of the transmission, the higher the number to more power its been made to handle, which should be a fairly reasonable estimate of durability in most cases.
The below article lists the transmission types fitted to each vehicle at the beginning of the VEs lifecycle. The 5L40E and 4L60E were scratched and replaced with the 6L50E for the series two VEs, except the LPG variants which carried on with the old 4L60E apparently.
Holden probably had some excess stock of 4L60Es to use up and figured that the extra fuel economy benefit of 6 gears wouldn’t be missed on an LPG vehicle with cheap fuel!
https://www.drive.com.au/news/holden-ve-commodore-transmission/
krusing
Melbourne, Bayside
That all depends on the Left & Right Foot !
My 22c worth ! (inc GST)
6L80E = 9/10
someguy360
The Shed
Various
Overall reliability is good, you WILL need to do timing chains at some point and it is expensive but thats engine reliability not trans.
Skylarking
123
Downunder
Commodore Motorsport Edition
Any auto's reliability, like any other mechanical item, depends on preventive maintenance. The biggest preventive msintenance item being periodic fluid flushes.
In most cases, failure is due to too long an interval between fluid flushes (and sadly the factory schedual isnt the best guide).
Crocodile
Gold coast
So what would you recommend.? Every 10 thou ?
