Blocked injectors??
Run some injector cleaner through it.
Blocked air filter and/or MAF sensor??
Replace air filter and clean MAF (carefully) with MAF Cleaner ONLY.
Faulty Throttle Position Sensor (TPS)??
Check for codes and replace if necessary.
Check vacuum hoses for leaks/connection.
Replace and or re connect hose/s.
