Samwhaaa
- Oct 7, 2023
- 4
- 0
- 1
- Age
- 39
- Location
- Melbourne
- VY Berlina
Hi all,
I've been searching for some answers with no luck as yet.
The A/C clutch doesn't engage when I turn on the Air con nor do the fans in the engine bay.
I tested the relay and it is fine, I've tried jumping the relay and the clutch engages.
The refrigerant should be fine as it was regassed in April with no leaks detected.
Mechanic says they will start with replacing the compressor and then go from there but I'm not convinced the compressor is the problem.
Any ideas or ways I could test anything else would be appreciated.
