I have the sam problem but am stuck... Urgent help please!!!!
Hi Ninja.... i need some urgent help please. My air con doesnt work and it sounds like what yours was.
I thought I was low on gas when it stopped working and took it to get regassed, they found it still didnt work and traced it back to the air con thermostat under the dash. Anyhow... we have manually bypassed switches by connecting 12v straight to compressor and got nice cold air... but I have been told it is bad to premanently rig up as can kill the compressor.
So I bought the thermostatic switch from GMH and we pulled the dash out. Now we're stuck. I can see the other thermostatic switch, but it seems to be glued in... and goes in the back of all this plastic casing. This sounds like the same switch you had to change with the green and brown wires. Did you have to get the casing off and if not how did you change yours?? Also can we do this without having to remove the actual evaporator, to avoid losing gas. and either way... evaporator in or out... how the heck do I do it from here??? Please help!!!
Michelle
