abs and batt light on????
lilkel
45
sydney
VP V6 BT1,VR 5.0l statesman
hi,
the battery light and abs off light has flashed 2 or 3 times over the last couple of weeks in my stato, it did it today and i put the car in neutral and gave it a good rev and they went out???? has this happened to anyone else and does anyone know what it is???? thanks in advance!!!
johnnyk
BF V6 Falcon
lilkel said:
hi,
Not sure about the ABS, but have you got a voltmeter? You can check your battery and alternator at least. Check the battery with the engine off (should be about 12v) and with the engine running, should be about 15v
kopper69
VRII Acclaim
Check for error codes to is a good place to start.
lilkel
45
sydney
thanks i'll give those things a go!!!!!
theburna
66
Wyee
VR Statesman
most likely the alternator
I just replaced mine doing the same thing
cost $180 with 2 year guarantee
