Advise on supercharging my vt 5.0L 383 stroker
WogBoyz
435rkw/590rwhp
Cairns, Qld
08 VE SSV M6 Ute
mate your comparing 2 completely different engines....not a wise suggestion!
Id definitely want my CR in the 9's before I force extra air down its throat...unless you run E85
Yes they are different however with that compression ratio he can run boost not massive amounts and with a good tune will be safe that's obviously making sure cam is compatible ect ect
I was just stating the ratio is ok for lowish boost
AirStrike
91' VN SS
It's not as straight forward as saying it's fine with that boost because a VE does, heads are different material, different chamber design, cam specs are different, etc.
mr j-man
GC
VH SL/E 355
who wants to run lowish boost??.....probably no one!
If your going to boost it do it properly and run something that can take 15psi plus....and get that CR down as low as possible otherwise itll be a nightmare of all things to come.
As airstrike and myself said its completely different regardless of comp ratio figures
Basically comparing apples to oranges....
Don't take it personally, no offence mate!
WogBoyz
435rkw/590rwhp
Cairns, Qld
08 VE SSV M6 Ute
"I want to run low boost" said no one ever haha
All good mate learn something new every day I suspose, thanks airstrike for the info aswell
Munz
Right Foot Action
Brisbane NTH
VZ Calais LS1 / VL RB30e daily
Could use a mains stud girdle instead of 4 bolt mains
Blu383
39
Yarrawonga
98 Vt supercharged 383 stroker
Looked at the girdles, are they worth it for this application? I know 4 bolt would be the way to go and as u may have guessed Ive spent a few $$$$ so far so I don't want to take the "easy" option if u know what I mean
mr j-man
GC
VH SL/E 355
how fast do you plan on spinning this thing??
Blu383
39
Yarrawonga
Supercharged and intercooled 383 stroker, should speak for its self! Lol
Dan355
Go THE SS's
Street Legal 355ci VN SS - Daily: VP SS
Not really!
You could be one of those people who want a 600hp street daily car that will hardly see over 6000rpm and will be quite happy to do so. OR you could be someone who wants a highly strung drag/track car.
Its all about the application its being used for.
Changing from one to another is the most expensive way to go about it.
If its the later then engine out strip the block, 4 bolt main conversion with some $$$ oiling mods + cam etc to keep it all together.
mr j-man
GC
VH SL/E 355
6 grand transbrake launches from the local Traffic Lights. lol
Ive got a 480hp 355 streeter and I find it hard to find roads where I can open it right up with out breaking traction.
Its all well and good having a killer engine like we all want to have....ideally id love a 6/71 on mine but where could I drive it.
you should start a build thread on this beast mate...id love to see pics and progress!!
