AIR BAG light?
HIROLLA
vic
VS SIII CAPRICE
Hi guys
My airbag light comes up on my stato. What should i do? How do i get rid of it? Has it happened to anyone before?
jafo
lurker since 2003
59
adelaide
1999 wh statesman
take it to a dealer and get the tech diagnostic done. and they can reset it with that. i had the same problem but it was my fault as i had the dash out and the ignition was turned on while the cluster was out so false reading was sent.
if you havent been stuffing around with anything and it came on by itself take it to a dealer and get it checked as it could go off premature and cause huge dramas better to be safe than sorry
HIROLLA
vic
VS SIII CAPRICE
Yea true
Thanks mate ill take it as soon as i can
Any idea on the cost?
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
If there is nothing wrong it can cost from $10 to $40 and takes 5 mins.
ecky308
44
vs berlina
The AIRBAG warning light comes on when the airbag is not functioning correctly. ie it will not go off, even in an accident.
This happened to my vs berlina a while ago.
My mechanic used the tech diagnostic to reset it but it kept coming on still.
Ended up having to replace the "air bag clock spring" in the steering column.
It's only a $5 part but the airbag had to come out and ended up costing me $200 with labour!
kopper69
VRII Acclaim
Good idea to check the fuse hasnt blown. Simple things like that. Otherwise Id definatly be off to the mechanics for that one.
