fonzo
- Feb 3, 2009
- 163
- 1
- 0
- vs berlina s2
Ok i own a panther mica vs berlina. on a 45 Degree day it gets mighttttttty hot after a day in the sun while im at work...ive had the air con gassed and with the climate control set to "C" fan on speed 3 and fresh air vent closed it gets to about 9 degrees. it has no leaks compressor i beleive is the factory unit is there anything i can do to get the air con below 9 degrees or is 9 degrees normal and im just expecting too much out of my air con? if 9 degrees is not normal where do i start to get the temps down to below 9 degrees........thanks
