Aircon won't turn on
VEpilot
40
VE sv6 series 2
Hi guys
Iv got a 2012 series 2 Ve commodore, the problem I'm having is the aircon won't turn on. The little symbol on the displays the frosty symbol has off underneath it. When I press the aircon button to turn it on it does nothing , even if I turn the demister on which should automatically use the aircon it still says off. I'm so frustrated as Iv just had the aircon regassed and new face vents actuators put in and now this and Iv only had the dam thing a few months. Any help or ideas would be much appreciated thanks guys
Mark
greenacc
Searching for the billion
VE Berlina
Why did you get it regassed was it working before that?
There is Probably a leak that wasn't fixed the first time.
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Out of gas again take it back, AC won't engage if gas pressure is too low.
Fairylegz
47
Central Queensland
VE SS 6ltr
Hi guys
Mark
I have just had a similar issue, turned out it was a the rubber pipe that had to be replaced!! I'll see if I can find my thread & screen shot the outcome!!
Fairylegz
47
Central Queensland
VE SS 6ltr
Found it
VEpilot
40
VE sv6 series 2
Hi guys
Thanks for the replys, I got it regassed because there was no cold air coming out, they told me they changed all the seals etc regassed and added dye too, Iv done 400km since then and now it's failed again , not happy but Iv taken it back and explained this .the so called aircon specialist is going to have a look at it tomorrow. Thanks for the heads up on the pipes though fairylegz il be mentioning that. Anyways il let you know what the outcome is shortly
Fairylegz
47
Central Queensland
VE SS 6ltr
Hi guys
Yes take it back they will see where the leak is due to the dye they added, Holden did this to mine 3wks later I had an appointment so they could see if it leaked & they found it. Rubber hose will be my guess but good luck
VEpilot
40
VE sv6 series 2
Fairylegz mate you hit the nail on the head , I dropped the car off this morning first thing and got a call late this arvo and geuss what he said there's a cracked high pressure hose and quoted me $600 to fix it, whilst I was choking at the price to replace a hose I had to have a bit of a laugh cause as was saying it was like listening to someone reading your email back to me over the phone. Well should get the full info tomoz il let you know .but thanks again for your help
Fairylegz
47
Central Queensland
VE SS 6ltr
I'm glad I could help lol.. That's cheaper than I was quoted, $780 at Auto Electrician to repair the pipe & gas!! Hate to know what the bill from Holden would have been as they used new pipe & gas, lucky it was under warranty
