alternator removal
99notout
VZ Equip Wagon
Her is the bit from the service manual...
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
i think youll find those are torx bolts and youll round them off if you use a socket.
edit* i could be wrong though.
These ones infact.
Benboy
Hill River, SA
2007 SVZ Wagon
Don't wish to keep this on-going however I have attached a photo of the retaining bolt on my VZ Alternator. It certainly doesn't look like a Torx bolt to me. Make up your own mind(s). Good luck.
99notout
VZ Equip Wagon
You are spot on Ben!
funaki
cartwright
holden commodore
Mine exactly the same with the retaining bolt off your alternator Ben.so its a hex headed bolt? I went to Super Cheap to buy a socket and the staff in the shop confused me.hahah but i think the pictures wil help them to get me the tools.thanks
Horacehighroller
70
Black Rock, Melboure
MY2010 Int VE11 Omega LY7 LPG Statesman 09 LY7
I used a 7mm socket but all the bolts were too tight and the socket slipped.
Then used a ring spanner with the same result.
Ended up using two nuts and tightening against each other and successfully removed the top bolt and front lower bolt but couldn't budge the lower rear bolt.
However, if you rotate the alternator forward about 100 degrees it is possible to get it off without removing the rear bolt.
