Alternator Voltage Questions ?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vsl67, Jan 14, 2012.
  1. vsl67
    vsl67 Member
    VS l67 statesman
    My battery died while driving recently I traced the problem to a stuffed alternator It was only putting out 12.1 volts and dropping to 11.3 volts going by the digital dash display ,So I swapped the internals from a VT alternator 100 amp into the VS l67 casing Now its reading
    13.8-14.1 volts while driving ,
    13.3 with aircon & lights driving
    13.8-13.9 @ idle in park
    13.1-13.2 @ idle in park aircon &ligths
    And the readings at the battery At idle are
    14.93 @ idle
    13.97 @ idle aircon and lights
    Does this sound right? Ive searched the forums and get a different answer everytime
  2. patrolking
    patrolking New Member
    brisbane
    VX series I I ss
    Sounds spot on to me
  3. wamboin23
    wamboin23 Donating Member w/ Boost
    Wamboin, NSW
    VS Calais - Cooled L67 + T56 | VR Acclaim V6
    are the first readings off the dash, or the back of the alternator?
    14.93v at idle is a bit high. i'd check that the sense wire at the battery (small red link going into a black connector) is attached and all good.
  4. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    The 14.93Vdc @ idle looks high to me....my limited experience and diminishing brain cells make me think it should be 14.2Vdc - was that measures at the alternator or at the battery?
  5. vsl67
    vsl67 Member
    VS l67 statesman
    The top readings are the dash displays and the last 2 readings are at the battery Terminals Just just rechecked the 14.93 at Idle looks like I made a typo its actually 14.23volts
  6. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Sounds a bit better!...volts at idle with lights and A/C on seem the wrong way around to me as when driving should be higher than at idle - is the one when driving done with the dash display and the one at idle with a multimeter?....
  7. vsl67
    vsl67 Member
    VS l67 statesman
    Yer thats right Driving using Dash display 13.8-14-1 and the 14.23 at idle at the battery with a multimeter
  8. BowTie
    BowTie Member
    VS V6 Acclaim
    i think you should quote the voltages to 3 decimal places.
  9. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    good quality multimeter or just a cheapie?
    unless it's something like a fluke use it as a guide they vary a lot in accuracy and most show a higher voltage as the internal battery gets flatter.
    the dash readouts are usually pretty spot on, try a fresh 9 volt battery in the dmm and recheck the high reading you posted.
    anything from 13.8-14.4 is the normal for an alternator at idle or just above idle as a base line with no load, turn things on and it'll drop as you've discovered and you'll probably start to hear it whine as it's loaded up more. all in all looks like it's working fine.
  10. BowTie
    BowTie Member
    VS V6 Acclaim
    While were here kicking the can around about this electricity thingymajigger,
    how's your charge wire?
    Now, would be a good time to rebuild it if you haven't already.
