Anyone in Melb (Dand) to install VS CAS?
existentialist
VS
Hey
I'm after someone/someplace to install my new CAS into my VS. I'm in Dandenong. Proximity would be preferred. How much am I looking at for the labour? (I will provide the CAS.)
Thanks
Pasticheny
wats a cas? im in melboure.. i want a cas ( even tho i dunno wat it is :p )
r_i_d_a_h
'97 VS Commodore + '98 E36
crank angle sensor?
r_i_d_a_h
it should be about maybe a 2 hour job at maxium? change ya harmonic balancer while ya at it! shouldnt cost more than $300 for parts n labour
Panama
'87 VL Calais with L67
took me 3 hours, but that was with an extra half hour's worth of trips to the auto one to get parts for a harmonic balancer puller that werent supplied.
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
if you have the correct tools changing a CAS shouldnt take more than 30 minutes
existentialist
VS
have you found any one yet? how come you cant do it? you seem to know?
CAS = Crank Angle Sensor
I've got one.. Got it new for around $50.
I would do it myself, it's just that ive read that you've got to be really careful and that it's hard to get the harmonic balancer off without the right tools...
I've read elsewhere on this forum that it can cost $60 ??
Panama
i bought the tool for $25.
just make sure you get three 80mm long, M6 thread bolts, and some washers, to suit the harmonic balancer as the bolts supplied in the balancer puller tool set are usually too big.
you will also need a decent 24 mm ring spanner to undo the center bolt that holds the balancer to the crankshaft.
be careful of your radiator and hit that mofo with a hammer so it undoes it without turning your motor over.
MUNTED6
Banned
vn berlina
i changed this bout 3 years ago when my old ladies vr harmonic was stuffed. i cant remember really well but i do remember that i didnt use no tool. all i did was use somthing like a screw driver to lever those small bolts then i undid the big bolt. and walla done presto. wasnt that hard was also my first time doing one. if i was still living in dandy which was a week ago id drop by and do it for ya but im all the way down sunshine now. hope all goes well for ya mate
