bcw61
- Sep 14, 2009
- 357
- 18
- 18
- Location
- Northern suburbs of Adelaide
- VZ 2005 Executive Wagon
The extra length of a wagon is the section behind the door not in the door itself.
Have seen statesman door trims on sedans and statesmans and wagons share the same floorpan.
Incorrect. The measurement from the datum point on the rear of the front chassis rail to the the datum point on the front of the rear chassis rail is 1030mm for the sedan & 1180mm for the wagon, so the floorpans are not identical. As an aside, I also found this out the hard way on my old VN wagon, when trying to fit new carpet for a sedan into a wagon, that VN sedans & wagon have different floor pans (the sedan carpet was roughly 50mm or so too short. Doh )
As for the doors, I would make absolutely sure that the sedans & wagon rear door trims are the same - even going to the point of actually measuring them.
Just checked the factory measurements for the sedan & wagon rear doors and as I suspected, they are different. The wagon door is 10mm narrower at the upper datum points (999mm versus 989mm).
Weekend Warrior above has probably summed it up correctly: the doors themselves are different, but the all the interior trims may possibly be the same. A few measurements, as I suggested, would confirm this.
PS: Is anyone after a brand new VN factory sedan floor carpet? LOL Guaranteed not to fit a VN wagon (double LOL)
