Astra AC dead, not compressor at fault ?
WL2005HBD
VIC
2005 WL Statesman HBD
Hi guys,
Sister's Astra A/C doesn't work.
Thought if test to see if it was the common compressor issue. Put a circuit tester over the compressor switch, no voltage no amperage. No change in RPM when A/C button is on, compressor isn't engaging either.
Light goes on the LED when the button is pressed though, where else could the fault be?
Thanks
Sent from my iPhone using Tapatalk - now Free
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
Hey mate, first point of call is gas. If there is no/low gas on the system, then the oressure switch will not allow the compressor to switch on.
WL2005HBD
VIC
But apparently these cars use the BCM to control revs as soon as you press the button, so shouldn't the revs change regardless?
Tasmaniak
41
S.E. Melbourne
News to me, the idle up signal has always been sent from the compressor to my knowledge otherwise it would burn excess fuel in the times that the ac is on but no compressor.
Simple test would be to get the pressure checked
WL2005HBD
VIC
True,
I remember I had this issue with my VP back in the day, low pressure switch kept kicking it on and off constantly and it was hell annoying.
But this car isn't even trying.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
on the front of the compressor under the coil is a thermal fuse it blows and you have no aircon very common on TS astras, it is a simple fix to do but a bugger to get at, make sure you have gas as well, have two astras (now only one) at home and this was the problem, one day it just stopped working, you can test the coil to see if it is, yes the comp controls the idle via the bcm but there is a vac hose on the throttlebody that has input aswell -senses drop in revs when a/c engaged etc etc and compensates etc etc, on the opel aus forum there is a fix for it, was sent to me in pic form and a brief outline on what to do
sidecar55
East of Melbourne
VE SS Series 1 9.5 Sportwagon/VE SS Series 2 Ute
Most likely is the compressor clutch coil, if you can find a good aircon guy he can replace it, if not, it'll be replace the compressor.
Micaxe
Kellyville NSW
9/17 SSV Redline & 83 VH SS
Cowboy will replace compressor, real repair is to change clutch coil, have had 2 in family so far, around $200 mark, compressor many times that!!
Mickcc
East Gippsland
Calais 2016 Series 2
I have the same problem
checked the voltage to the coil no volts
to engage the clutch on the Air Com pump
30A fuse good light green light on
Air Con Switch on and fan on high
now where do I find the pressure switch
can see the gas points up against the Fire wall and one near the grill all on the RHS of the car
cheers
losh1971
North Tas
VE Series I SS Ute
As noted above, the common issue with these is the clutch coil.
