I believe the flow rate on the astra pump is lower giving slightly heavier steering than the volvo pump
Plus, if going a used item, the volvo pump is much newer
Also, IRT wiring, it seems most people joint both of the small power wires, but, the correct way is to not join them is NOT to join the wires, one is goes to switched power and one is to ignition, or something, this stops the pump from starting as soon as you turn on the ignition, and only starts the pump once the engine is running, there is also talk about when you run the wires from the different feeds it makes the pump more responsive when changing directions
Apparently joining the wires causes an initial lag in steering response
I've been doing alot of desk top research into all the different makes of electric ps pumps, there location to the rack (the closer the better), and the correct way to wire
Apparently the stock electric pumps have 3 power wires for a reason, 1 heavy gauge main power wire, and the 2 other lighter power wires to make the pump work like it is meant too
Electric ps is one of the mods I want to eventually do to my VX SS, probably when I relocate my battery to the boot when I am looking for more realestate for a larger reservoir for my interchiller
